Date/Time: Wed, 05 Feb 2025 13:01:36 +0000
trade activity
View Count: 701
[2020-03-13 09:30:29] |
stephane1 - Posts: 112 |
hi , Why "Trade activity log" -> "Statistics" (is empty) doesn't work in real time with sim account ? tku |
[2020-03-13 16:44:06] |
Make sure you are using this properly. Instructions: Trade Activity Log: Trade Statistics Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-13 19:31:56] |
I checked all seems to be correct .. only the tab"chart stat" works the other tab are empty.
[2020-03-14 00:46:00] |
Do you see the order fills on the Trade Activity tab of the Trade Activity Log? You need to have order fills there for the Trade Statistics to display any statistics.
[2020-03-14 07:01:09] |
I see order fill only when "Trader Mode Simulation" is OFF (real account), but when I trade in "Trader Mode Simulation Mode"= ON (Sim# account) I don't see order... (my data feed Rithmic- symbol MES0)
[2020-03-17 04:48:18] |
Provide a screenshot of the entire Trade Activity Log window after you select Trade Activity at the top.
