Date/Time: Wed, 05 Feb 2025 11:55:02 +0000
Menu near the top of a chart
View Count: 510
[2020-03-12 21:50:41] |
User707404 - Posts: 34 |
I just downloaded the newest version of Sierra Charts due to a note that the new version is now available. However after I did that, all the "tool commands" near the top of the chart page are now in a typed word version. With the previous version this line of commands included drawn icons of some of the commands. For example the Hand Tool is now typed Hand...in previous version it showed a drawing of a hand. How do I convert all these typed commands back to the version that included drawings - for examples that were drawings - line, hand, ray, parallel lines chart calculation.....etc. Thanks.
[2020-03-12 23:06:12] |
You can use the old small icons. This is explained in detail here: Control Bar: Control Bar Button Properties Be sure to follow step 10. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
