Date/Time: Mon, 25 Nov 2024 03:52:49 +0000
More data disconnections
View Count: 1255
[2014-01-09 16:33:35] |
Peter Power - Posts: 70 |
Hello, I am experiencing more and more datafeed disconnections. It happened again today at 16:22 GMT time. Can you have a look at it? |
[2014-01-09 16:46:01] |
"More and more data feed disconnections"? This does not make sense. Yes, we are aware of a problem at 16:22 with the Sierra Chart CME data feed and this problem has been resolved. But other than this, you should not have any disconnections. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-09 22:26:58] |
We do know there was an interruption today, but other than that, there has not been anything recently. When we work on our servers, sometimes we do transfer users over to another server which would look like you get disconnected for 3 seconds and then you are reconnected to the next server. This is just nothing more than normal operation and there is no missing data because upon the reconnection any missing data is automatically downloaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-10 11:24:10] |
I wrote it because previously we have been solving the issue of regular disconnections between TWS and SC. I tought that this is the issue again. However, after the yesterday´s interruption I was downloading the missing data for all markets which I am trading currently, using the EDIT->Delete all data and download function. And I successfully downloaded data for all markets except EMD. If I do the same on EMD, I still see the gap from 16:22 until 16:38 GMT. |
[2014-01-10 16:35:56] |
Disconnect issues with TWS have to be taken to Interactive Brokers. We will be patching the missing EMD data. We confirmed that when you do lose connectivity to TWS, that the Sierra Chart data feed will continue to work as long as you do not select File >> Disconnect. And have Global Settings >> Data/Trade Service Settings >> Reconnect on Failure enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
