Date/Time: Wed, 05 Feb 2025 12:03:43 +0000
Stop Order Fills Total
View Count: 519
[2020-03-11 17:04:20] |
SierraTraders - Posts: 69 |
When using the "Stop All" with multiple targets/contracts is it possible for the stop order position line to show the total currency for all stop targets/contracts it currently seems to only show total currency for 1 target/contract |
StopOrder.png / V - Attached On 2020-03-11 16:57:43 UTC - Size: 81.09 KB - 192 views |
[2020-03-12 05:51:25] |
Revised the attached pic
StopOrder2.png / V - Attached On 2020-03-12 05:50:19 UTC - Size: 93.04 KB - 200 views |
[2020-03-12 09:53:02] |
No this is not supported and is difficult to implement.
