Date/Time: Wed, 12 Mar 2025 11:42:58 +0000
Number bars on daily time frame
View Count: 1442
[2020-03-11 16:06:55] |
User135370 - Posts: 162 |
Hi I open a historical chart on a daily time frame and add the Number bars study and get all Zeros. Am I missing something? |
[2020-03-11 16:18:07] |
John - SC Support - Posts: 38598 |
You cannot use the Numbers Bars with daily data. Refer to the information here: Numbers Bars: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-18 14:37:15] |
User840539 - Posts: 25 |
Well, if you press on Daily as timeframe, it shows all zeros, but if you change settings in Chart Setting as pointed below, it works just fine. Try it for yourself :)
Date Time Of Last Edit: 2021-03-18 14:37:29
[2021-03-18 15:24:39] |
Yes, that is correct, because in that case you are using the Intraday data. Sorry if our terminology was confusing. When we stated "Daily Data", we were referring to the data that we store as Daily (historical data). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
