Date/Time: Wed, 05 Feb 2025 11:53:29 +0000
tradovate and Sierra
View Count: 638
[2020-03-11 15:40:40] |
User911406 - Posts: 1 |
hello! is it possibel to trade with tradovate through dorman and use sierra with denali data feed?
[2020-03-11 20:30:08] |
Yes. You will be using CQG and the Denali Exchange Data Feed can be used with CQG.
