Date/Time: Mon, 24 Feb 2025 12:25:35 +0000
Attached orders do not get updated automatically anymore on IB
View Count: 615
[2020-03-11 15:07:16] |
Mauro - Posts: 45 |
Hello, something happened with the IB interface. If I put an order with target and stop attached, if I move the order before it gets filled the attached orders don't follow. The attached orders do not get updated. Same thing if I have a break even in place. The stop doesn't get updated to break even. It all works in sim mode of course, and it used to work with IB too just few days ago. I tried to install an older version of sierrachart, I tried a new install on a different computer, I tried with TWS and IB gateway. No luck Does anybody else have the same problem? Thank you Mauro |
[2020-03-12 09:16:51] |
We recommend you disable this option: Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General) If you are trading CME group futures with Interactive Brokers and you still want server-side bracket orders, then use this service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-12 09:17:06
[2021-03-11 20:58:47] |
User379468 - Posts: 508 |
The issue in the original post appears to be resolved and it seems to be working correctly. Can you clarify if you still recommend disabling server side bracket orders with IB and why? |
