Date/Time: Wed, 05 Feb 2025 11:46:48 +0000
Chart data files
View Count: 472
[2020-03-11 10:59:59] |
EuropeanTrader - Posts: 290 |
Hi, please see attached pic. Intraday data files are getting huge. Is there a way to reduce this size? Thank you. Greg |
SH_ 5348 Mar. 11 11.58.jpg / V - Attached On 2020-03-11 10:59:53 UTC - Size: 45.94 KB - 233 views |
[2020-03-11 17:51:02] |
Refer to the following: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#IntradayDataFileManagement And then, you can also delete files for symbols that you are not following. Refer to the information here: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
