Date/Time: Wed, 05 Feb 2025 12:01:37 +0000
[Programming Help] - Zig Zag trend in spreadsheet
View Count: 824
[2020-03-11 10:46:57] |
User354816 - Posts: 21 |
Hello, I want to define a trend via spreadsheet text labels. If the last is HH and the one before is HL = long. Is there any formula i can use for ? Thanks ! |
Screenshot_148.png / V - Attached On 2020-03-11 10:46:29 UTC - Size: 24.54 KB - 261 views |
[2020-03-11 12:52:25] |
Sawtooth - Posts: 4167 |
Here are the text label value conversions: Zig Zag: Text Labels Subgraph Description Next you would need to make the previous ZZ leg's text label value persistent so you could compare it to the current text label value. See this example: Spreadsheet Example Formulas and Usage: Return Last Two Zig Zag Reversal Values |
