Date/Time: Wed, 05 Feb 2025 11:54:17 +0000
Eurex activation
View Count: 656
[2020-03-11 10:26:32] |
User182649 - Posts: 31 |
I am currently subscribed to the Denali data feed for CME products. To activate the Eurex ( really all I need is the Dax mini), will I need to subscribe to the Sierra chart data feed instead? Thanks |
[2020-03-11 22:18:58] |
You will need to use the Sierra Chart Exchange Data Feed in addition to the Denali Exchange Data Feed. When you do this, we will discount the cost of the Sierra Chart Exchange Data Feed by $10 (implemented through an automatic refund). You will then get the CME data from the Denali feed and the EUREX from the Sierra Chart feed. Refer to the Setup Instructions here for the Sierra Chart Exchange Data Feed: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions We can help you through the setup process if you would like. Just let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-11 22:20:11
