Date/Time: Mon, 25 Nov 2024 04:35:30 +0000
Copy Chart Drawing for Chart # ACSIL
View Count: 1367
[2014-01-09 05:46:20]
onnb - Posts: 662
The chart UI has the above option. I don't see that it exists in ACSIL.
Meaning say I do the following:
1. I open two charts.
2. On chart 1 I have a study that draws a line with AddAsUserDrawnDrawing = 1
3. On chart 2 settings defined to have drawings copied from chart 1.
Only when setting AddAsUserDrawnDrawing = 1 I'd expect it to work the same as when I do this manually.
Onn
[2014-01-12 03:15:50]
ejtrader - Posts: 688
+1 on this. Would be nice to have this done - when the drawing is done through ACSIL as well.
[2014-01-16 03:53:27]
This is not supported. This is by design.
What you instead need to do is have your ACSIL function add the chart drawings to the specific charts that you want.
There is a s_UseTool::ChartNumber member which can be used for this purpose.
