Date/Time: Wed, 05 Feb 2025 11:54:54 +0000
Hi I wanna activate a service package with new broker Tradovate
View Count: 542
[2020-03-11 02:16:26] |
Caio L Avila - Posts: 1 |
On 3/11/2020 12:03 AM, Caio Avila wrote: > Hi > I wanna make setup my account with TradoVate instead Stage5, and how much cost to use again the platform. > Can I use CQG? Data? (That’s I’m using with TradoVate) , > Thank you > To make easy for me do you have any link? I’m not good with setups. > Thx Again > Caio > Date Time Of Last Edit: 2020-03-11 17:46:48
[2020-03-11 17:46:37] |
CQG is supported. Instructions: CQG Trading Platform Service: Setup Instructions For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
