Date/Time: Wed, 05 Feb 2025 11:47:51 +0000
Re-center on chart scroll
View Count: 1327
[2020-03-10 23:40:41] |
User745789 - Posts: 356 |
Chart Scale and Scale Adjusting: Re-Center On Chart Scroll (Scale Range) Using Constant Range. Check Box is not selected. Chart still automatically attempts to recenter (sometimes wildly) when I manually scroll via the Hand cursor. |
[2020-03-11 18:01:39] |
If you do not want the scale to change at all as you move through the bars then make sure that Scale Settings >> Constant Range Scale Mode is set to Manual Mode. Otherwise the scale is going to move based on what is set there. Refer to the following: Chart Scale and Scale Adjusting: Constant Range Scale Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-12 04:07:03] |
Understood, I think. But then don't I lose auto-recenter due to price movement. Perhaps I have misunderstood the meaning/purpose of the "re-center on chart scroll" check box. Ideally, I don't want the chart to auto-center unless the last bar is within the chart window. If I have scrolled way from there, then no auto-recenter.
