Date/Time: Mon, 25 Nov 2024 04:52:18 +0000
Problems with quote board on the most recent update
View Count: 1347
[2014-01-09 05:20:53] |
Wayne Hochstetler - Posts: 1 |
I am not able to edit the quote boards since I updated to version 1074. I have 3 computers, 2 are updated to version 1074, both have the same problem. The 3rd computer is on version 1068 and it is able to edit the quote boards. Thank You |
[2014-01-09 22:30:21] |
We do see a problem related to this and we are looking into it.
[2014-01-11 19:19:48] |
We apologize for this. This is now going to be fixed in 1077 which are releasing now. It is not good that such a basic feature was not working right for several days now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
