Date/Time: Wed, 05 Feb 2025 09:54:25 +0000
CHART NOT UPDATING
View Count: 520
[2020-03-10 18:33:18] |
User55314 - Posts: 7 |
http://www.sierrachart.com/image.php?Image=1583864925515.png Hi, my chart is not updating only for aapl symbol. Others are fine. |
[2020-03-10 18:41:47] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
