Date/Time: Wed, 05 Feb 2025 10:49:46 +0000
Sierra Charts software not working properly
View Count: 737
[2020-03-10 15:36:40]
Camila - Posts: 21
Hi
Since more than one week ago the SC program is not working properly.The charts will not update real time. If I choose any option of the menu (even when I choose the pointer, for example) the screen becomes light gray and the round circle pointer starts to go round for about a minute to get into what I have asked for.
I am not able to see the updated charts as the program is constantly retarded. And when I try to do something with the program it is impossible!!
I have gain data feed.
thanks for your help.
Camila
[2020-03-10 18:03:46]
The first thing we want you to do is to run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
Let us know if that resolves the problem.
If not, attach the Chartbook you are using by following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2020-03-13 21:36:51]
Camila - Posts: 21
The program will run ok under safe mode.
However, when I run the platform on normal mode, the program is sluggish and it displays the round circle pointer and stays almost frozen for several minutes. I can do almost nothing on sierra charts
The chartbooks I am using are attached.
Thanks for your help
Camila
Private File
[2020-03-15 09:49:39]
Watch this video in regards to this:
https://www.sierrachart.com/Videos/Improving_Sierra_Chart_Performance.mp4
We did look at the Chartbook and you have one Volume Value Area Lines study that is taking 90 seconds for a full recalculation. In the Input settings, you need to increase the Ticks Per Volume Bar and reduce the number of days loaded in the chart.
