Date/Time: Wed, 05 Feb 2025 09:50:59 +0000
Window issues
View Count: 668
[2020-03-10 15:27:25] |
User161549 - Posts: 81 |
Having an issue with the main window on Sierra chart I have many other detached windows but the main one is the only im having an issue with Everytime you go to make the window smaller for example having 2 different charts on the same screen the window disappears and the only thing that is left is the toolbar at the top of the page that allows you to minimize/maximize the page and "X" out of the page The only way I can get it to pull back up is by completely maximizing the page I have closed and re opened the program several times still no luck |
[2020-03-10 18:36:49] |
We want you to select Window >> Reset Windows and then restart Sierra Chart.
[2020-03-10 18:37:44] |
Also, it sounds like the chart windows are outside the view of the main window when you unmaximize them. There are a number of options available to resolve this, but the simplest is to just select Window >> Tile Horizontally. This will tile all the chart windows in the viewable area and then you can move them around from there. Also, be aware of the following setting: General Settings Window: Enable Workspace Scrolling (Global Settings >> General Settings >> GUI >> Scroll) Refer to the post above as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-10 18:38:09
