Date/Time: Wed, 05 Feb 2025 10:57:17 +0000
error writing record to C:Sierra Chart
View Count: 1258
[2020-03-10 10:55:53]
User40526 - Posts: 166
I am using SC and Rithmic in a Top Step SIM combine.
Last night I began to get this error code when I entered a position.
Error writing record to C:\SierraChart\TradeActivityLogs\TradeActivityLog_2020-03-10_UTC.*S2Mar10294935.data. Windows error code 123: The filename, directory name, or volume label syntax is incorrect. | 2020-03-10 05:48:02.862 *
I took 2 long trades, one a scratch and the other for +330. Sierra Chart shows both as shorts with one as an 8 tick loser (-80) and the other as an open position, while Rithmic shows them correctly.
Please advise.
Thank you
[2020-03-10 11:42:52]
Could you contact Top Step Trader and tell them only to include letters and numbers in the account identifier. So they need to change your account ID.
[2020-03-11 02:42:21]
Thank you, but I am now a ping pong ball between SC and Top Step.
Top Step claims no one else using SC and Rithmic has this problem.
I can't imagine anything I did to cause this. I just went from their Step 1 to Step 2 and they added the * to the beginning of my ID. I don't know why I would be the only one they ever did that to, but who knows.
Thank you
[2020-03-11 06:15:29]
Not sure why they would tell you that. But we will contact them now in regards to this.
Date Time Of Last Edit: 2020-03-11 06:15:36
[2020-03-11 18:45:40]
I am frustrated, so forgive me.
It is now 1:44pm my time and I have not heard anything from Top Step. I have emailed them again. It doesn't help to call.
It seems they must not want us to use Sierra Chart, which is a shame.
[2020-03-11 18:52:41]
We apologize. We did not yet contact them. We are going to do this today.
Yes this does make sense because we told them that. We want to them to remove support for Sierra Chart. We do not want users using Rithmic any longer.
Date Time Of Last Edit: 2020-03-11 18:53:03
[2020-03-11 19:56:09]
just got a call from Top Step and they say there are many TST traders in the same combine I am in, using SC and Rithmic, and they all have an asterisk in their ID and have no problem.
I am happy to fix whatever I need to on my end if I can only find out what it is.
Thank you
[2020-03-12 02:53:00]
We have contacted Top step Trader about this and they quickly responded, and they are going to take care of the issue for you.
Date Time Of Last Edit: 2020-03-12 02:53:05
[2020-03-12 14:46:46]
Still have the issue today and no response from Top Step.
[2020-03-12 15:51:33]
I just talked to Top Step and they say they think there may be an indicator that I use in Sierra that is causing the error message.
Since all that happened was that I got a new ID and immediately began having the problem, I have no way of knowing what indicator could be causing the problem, assuming that IS the problem. I made no changes to my set up when I was given the new ID.
They say they can't help me, since they maintain it's not a Top Step problem and that other clients of theirs who have the same ID, letters - numbers - and asterisk, who use SC and Rithmic don't have the problem. If that's true, then for some reason I am the only one with a problem that no one can identify. I am not a programmer or tech person and couldn't possibly know what to do.
Someone has to tell me what to do.
Please help me. This has been going on for 3 days. It is beyond distracting.
Thank you
[2020-03-12 18:19:39]
No that is not true. We know exactly what the problem is.
And this is what they just told us today in regards to your account:
Yes, we're working on a fix for him specifically. Hope all is well for you guys in these crazy times!
Does your trade account still have an asterisk?
[2020-03-12 19:07:26]
Yes. The account STILL has an asterisk.
Thank you for responding.
[2020-03-12 19:46:15]
They need to remove that *.
[2020-03-12 19:47:15]
We could potentially implement a solution from our side, but if we then use a replacement character for the file name and it is a character that could then be found in a Trade Account, we then create a new problem. This is why they just need to remove the *.
[2020-03-12 23:02:45]
Incredibly I am still waiting for a resolution, going on 4 days.
I called late this afternoon and a support person said, yes we are aware of the problem, but couldn't provide a fix. He said his manager. James. would contact me. I'm waiting!
Sorry to be a PITA, but I'm really frustrated.
[2020-03-13 00:30:01]
Ok we will just have to translate that character to something valid for the file system. We could use ! but the question is are there other accounts which contain that.
Let us think up something.
[2020-03-13 00:46:35]
We will have a solution out in a couple of hours for this.
[2020-03-13 13:36:00]
I still have the problem today with the error messages popping up every time I do anything with an order.
Top Step claims to be working on it. Four days and counting.
[2020-03-13 13:48:08]
ok, gonna have to quit until someone can figure this out. orders entered now are being rejected for some reason and the order will be a sell and the rejection will state it was a buy???
really a mess
[2020-03-13 16:12:20]
We have already released a solution to this. Update with Help >> Download Prerelease. Instructions:
Provide us the rejection message:
Support Board Posting Information: Providing Lines From Trade Service Log
Date Time Of Last Edit: 2020-03-13 16:13:17
[2020-03-13 16:38:07]
OMG!
Thank you!
No need to send you the other rejection message. It doesn't appear with the pre release.
[2020-03-13 16:40:50]
But nothing has changed with order processing with Rithmic between the version you are running and the latest prerelease.
So the update is only coincidentally resolving the issue in regards to the rejection you were getting.
Date Time Of Last Edit: 2020-03-13 16:41:12
