Date/Time: Mon, 25 Nov 2024 03:41:31 +0000
[User Discussion] - latest sierra chart update applied
View Count: 1315
[2014-01-09 03:15:44]
toews&kane - Posts: 209
After the update was applied the columns on my spreadsheet moved over to the right one, but there's one zero column at the start.
So the data was from EH-EK, now it's at EI-EL, while EH is all zeros I just realized.
How do I change this back to the way it was?
If I delete column EH any reference to it would be gone so that doesn't work. I don't want to have to manually go through all my formulas to change them?
[2014-01-09 04:24:41]
also having to make another change
in the H columns if I have reference to any of those cells if I use absolute value $H$3 it will come up as a referencing error
[2014-01-09 05:32:43]
I don't know what's going on I just got pushed another update, the spreadsheet layout looks different and now all my formulas are gone it's just a blank sheet
imageCapture.PNG / V - Attached On 2014-01-09 05:32:41 UTC - Size: 35 KB - 415 views
[2014-01-09 06:12:48]
I hope there's a way to revert this because my last backup of my computer was 12/25
one thing I noticed also is after this latest update, the size of my spreadsheet shrank from 300~kb to 134kb
[2014-01-09 06:13:19]
also workbook explorer is blanked out
[2014-01-09 08:15:19]
In response to the last 3 posts, you are running the non-CLR version of Sierra Chart. That version contains our new spreadsheets which are still under development.
[2014-01-09 16:45:36]
So why am I offered this update?
how do I fix this?
[2014-01-10 05:34:37]
You need to select Help >> Download Current Version to get the standard version.
Previously you must have selected Help >> Download Latest Non-CLR Version.
Date Time Of Last Edit: 2014-01-10 05:34:56
[2014-01-10 10:27:04]
Post #1. You will need to update your formulas. Sometimes this can happen when there are changes to studies.
In the non-CLR version with the new spreadsheets, this will not be a problem anymore because study subgraphs can be referenced by ID number not by cell references.
Post #2. We do not know what to say about this. We see no reason why this would happen but we do not know exactly what you are doing and exactly what is in the Spreadsheet. It is best for you to troubleshoot this on your own. Start off with a clean spreadsheet and try to go from there and see what the problem is.
