Date/Time: Wed, 05 Feb 2025 09:55:49 +0000
TPO Profile Range in Ticks/Points
View Count: 818
[2020-03-09 23:14:46] |
User120942 - Posts: 71 |
@Sierra Chart Engineering, The current list of displayable statistics in the TPO study does not permit me to display the range of each profile (high to low) in points and ticks. I am able to see these values in the Chart Values for Tools window under the Univariate Summary. But I would like to be able to select these values to be displayed on the chart. Can the Univariate Summary statistic be added to the current drop down list for the Chart Value to be Displayed on Profile or can this be accomplished through some other study to display the range on the chart for each profile as text above or below the profile? Your consideration is appreciated. Thank You |
Chart Values for Tools.png / V - Attached On 2020-03-09 23:14:19 UTC - Size: 45.63 KB - 254 views |
[2020-03-10 18:06:52] |
Yes we will add all of those additional TPO values in the Chart Value to be Displayed on Profile TPO profile Chart Study Inputs.
