Date/Time: Wed, 19 Mar 2025 04:33:29 +0000
How many instances on one computer?
View Count: 1944
[2020-03-09 19:54:24]
User866343 - Posts: 1
Hello SC Support,
On the same computer, how many instances of SC can I use with the data services? I know that it is limited to 2 connections on two different computers, but can I open 8 or 10 instances of SC on the same computer/same data connection?
Thank you.
[2020-03-09 21:15:18]
Yes you can open 8 or 10 instances of Sierra Chart on the same computer/same data connection (or more). There is no limitation to this setup from our end. It is just a matter of what your computer can handle.
[2022-10-12 19:16:59]
ProfitableTrader - Posts: 22
If you have 3 or more data connections with different brokers, can you only login to two of them at a time ?
The typical use case am considering is prop firm accounts. Mostly, they tend to be Rithmic paper trading accounts and configured as a Rithmic Direct connection . Note that I also have Denali data feed, not sure if that is helpful when configuring a Rithmic connection though .
[2022-10-12 21:18:09]
John - SC Support - Posts: 38782
Actually, the number has changed recently, so you can have 3 connections from different Sierra Chart installations to the Denali Exchange Data Feed.
Therefore, if you have 3 different brokers, and therefore 3 different installations, you will be able to connect all three to the Denali data without any problem. If you were to have a fourth, then one of the installations would not get data.
There are options if you need them for having data to more than 3 installations, but it means either using a second computer or having another Sierra Chart account. If you need us to go over these options, let us know.
[2022-10-12 21:32:22]
Thank you for the response, John! Does the 3 data connection limit apply only when using Denali? Or would that apply even when using Rithmic data provided by the prop firm?
[2022-10-12 21:36:41]
Just to Denali. We do not know what Rithmic connectivity allows.
[2022-10-13 09:32:59]
Thanks John.
I have Sierra chart on two computers only. Don't seem to be getting real time data even for the the second process. Please advise.
SC DTC Delayed Exchange Data | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 | 2022-10-13 09:24:28.935
SC DTC Delayed Exchange Data | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 | 2022-10-13 09:24:28.935
[2022-10-13 10:14:34]
Sierra_Chart Engineering - Posts: 18837
No of course you cannot get real-time data on two computers at the same time from the CME. They will not allow that unless you pay a second exchange fee. The information quoted above is for delayed data.
Refer to:
Denali Exchange Data Feed: Connections
[2022-10-16 22:42:23]
Thanks John! At present I'm able to connect to two separate Rithmic Direct connections on the same computer and initiate trades. Was also able to connect to a separate third Rithmic connection and view my accounts as well.
However, not able to initiate any trades on the third one. The error I get is:
Rithmic Direct - DTC (Order reject). Info: User not entitled to trade on this exchange. Internal Order ID: 137. Service Order ID: 1484289753. Symbol: MESZ2.CME. Account: ********** | 2022-10-16 17:38:22.312 *
On all accounts, I have market data and historical data username/password set to the Rithmic credentials. On the third connection, I tried leaving the market and Rithmic connection blank hoping it will use my Denali feed. That has not solved the problem though.
Please help.
[2022-10-16 23:37:55]
We do not know what the problem is. You need to ask Rithmic about that error message. It is from them.
Date Time Of Last Edit: 2022-10-16 23:38:13
[2022-10-17 09:15:08]
thanks much! Is there any limit to the number of unique trade services connected from a single computer? The problem is happening only when connecting to the third service, however I have not yet tested the failing service independently
[2022-10-17 11:08:59]
Sorry, my configuration was pointing to the wrong server (it was not local.) Not sure if that was the issue. However looking up trade activity, I saw that orders were going to the sim account. Upon disabling sim I am able to see my orders! Thanks much!
[2022-10-17 11:19:57]
There are absolutely no limits whatsoever on the Sierra Chart side related to this.
