Date/Time: Wed, 05 Feb 2025 09:55:28 +0000
placing orders on future options contracts
View Count: 530
[2020-03-09 18:22:01] |
john baker - Posts: 12 |
I want to buy calls of crude oil options in sept or aug how do I do this?
[2020-03-09 22:15:05] |
First we want you to update Sierra Chart to the current version: Software Download: Fast Update And based upon the Service you are using in Sierra Chart, you are only accessing market data and not using a Trading service. So are you referring to just doing simulated trading for futures options? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
