Date/Time: Wed, 05 Feb 2025 09:56:39 +0000
P & L when using
View Count: 620
[2020-03-09 17:45:07] |
User316362 - Posts: 210 |
v 2060 (and 2057 before)... The P/L becomes wrong if a "trade and Current Quote Symbol" is entered in the chart settings. It doesn't match either symbol. Also, if "Use only as trade symbol" is checked...it changes yet again. It doesn't match either symbol. I would think that if "trade and Current Quote Symbol" is entered and the box is "unchecked" that the P/L should be the Current Quote Symbol. |
[2020-03-09 19:06:12] |
What profit/loss value are you referring to? Make sure the Currency Value per Tick in Chart >> Chart Settings is set correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-09 19:07:49
[2020-03-09 20:07:50] |
Yes, I checked. On the chart that has Main SYmbol as ES and "Trade and Current Symbol" as MES for instance, I found the difference/issue It's the subtraction of the commission. When using MES in the "Trade and Current Symbol", the profit per tic is calculated properly but it subtracts the ES commission versus the MES commission. Can this be corrected? Date Time Of Last Edit: 2020-03-09 20:26:19
[2020-03-10 18:03:20] |
Any thoughts concerning the commissions above?
[2020-03-10 18:07:51] |
We will implement a solution to this. We thought of a reasonable way to do this.
