Date/Time: Wed, 05 Feb 2025 08:57:21 +0000
Is the Paintball Countdown Timer or something like it available these days? Thx
View Count: 520
[2020-03-09 00:48:34] |
User14953 - Posts: 241 |
Remember the Paintball Countdown Timer that worked with SierraChart? The selectable colors and size changed as time neared by selectable percentages closer to the next bar. User could drag and drop it around the chart for placement. Very visually effective at just a glance. Is the Paintball Countdown Timer or something like it available these days? Thx |
[2020-03-09 04:01:15] |
Yes the Countdown Timer study supports setting the colors and size and it is adjustable by moving it around the chart interactively. Refer to: Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-09 04:01:25
