Date/Time: Wed, 05 Feb 2025 08:40:40 +0000
Export data to text file
View Count: 717
[2020-03-08 13:24:28]
User860680 - Posts: 6
I would like to ask, if it is possible to set, what format of data should be exported to text file? I would needed this format of data - Date/Time/Open/High/Low/Close/Volume, without NumberOftrades/BidVolume/AskVolume.
Thank you
[2020-03-09 16:29:47]
No it is not possible to change that format. You have to edit the data after through a Spreadsheet program to get what you need.
Date Time Of Last Edit: 2020-03-09 16:30:14
