Date/Time: Wed, 05 Feb 2025 08:41:05 +0000
data service question
View Count: 502
[2020-03-08 00:45:48] |
User811622 - Posts: 38 |
I'm confused with new announcement from Sierra Chart about using Denali and not using Sierra Chart Exchange Data Service. I have AMPfuture/CQG account. I purchased Sierra Package 5. I plan to go back to get CME data through AMPfuture. But I still need Stock NYSE/Nasdaq data through Sierra Chart. Which service do I need with Sierra chart? Thanks |
[2020-03-08 06:30:34] |
You do need to continue to use the Sierra Chart Exchange Data Feed. But you are not impacted by the announcement if you were not using more than one real-time connection. Even if you were, you just need to share data from that connection to multiple instances of Sierra Chart: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-08 06:51:09] |
If I don't continue to use Sierra Chart Exchange Data Feed to use see NYSE/Nasdaq, what other options do I have?
[2020-03-08 07:03:59] |
There are no other options at this time. We do plan to offer US equities data as well as other exchanges on the Denali Exchange Data Feed, in a few months.
