Date/Time: Wed, 05 Feb 2025 08:38:42 +0000
Using data from 1 brokerage and executing through another
View Count: 740
[2020-03-07 23:03:35]
User525965 - Posts: 153
I have a broker i like to use to execute my trades, however there data fees are much higher than i pay with another account i have. Would I be able to use the data feed from 1 of my brokers (CQG -AMP) to trade that account and to trade another account from another broker?
[2020-03-08 06:28:06]
Yes technically you can but the proper solution in this case is to use the Denali Exchange Data Feed:
But here is the documentation for what you are referring to:
https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart
[2020-03-08 19:43:16]
Thank you!
Why do you recommend using Denali, will the other way not work very well?
[2020-03-08 22:34:16]
Using the Denali Exchange Data Feed is the proper solution to this. And the other method is more technically involved.
Date Time Of Last Edit: 2020-03-08 22:34:24
