Date/Time: Sun, 04 Oct 2026 07:26:38 +0000
wont connect to data feed
View Count: 1098
[2020-03-07 18:30:06]
scotte721 - Posts: 8
Reading Internal Order ID file. | 2020-03-07 10:26:08.892
Reading Trade Orders file. | 2020-03-07 10:26:09.013
Reading Trade Positions file. | 2020-03-07 10:26:09.015
Reading Account Balance file. | 2020-03-07 10:26:09.016
UDPListener (1408). Port 22904 | Listening on UDP port 22904. | 2020-03-07 10:26:09.040
Software version: 2060 64-bit | 2020-03-07 10:26:09.040
Enabled for: Sierra Chart Historical Data Service. | 2020-03-07 10:26:09.040
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-03-07 10:26:09.040
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-03-07 10:26:09.040
Current selected Data/Trading service: CQG WebAPI | 2020-03-07 10:26:09.040
Custom symbol settings values: disabled | 2020-03-07 10:26:09.040
Chart Update Interval: 500 | 2020-03-07 10:26:09.040
Intraday Data Storage Time Unit: 0 | 2020-03-07 10:26:09.040
Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-03-07 10:26:09.040
2020-03-07 10:26:09 Local computer time | 2020-03-07 10:26:09.041
2020-03-07 18:26:09 Local computer time in UTC | 2020-03-07 10:26:09.041
2020-03-07 10:26:09 Local computer time in SC Time Zone | 2020-03-07 10:26:09.041
2020-03-07 18:26:08 Server time in UTC | 2020-03-07 10:26:09.041
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-03-07 10:26:09.041
Program path: C:\SierraChart\ | 2020-03-07 10:26:09.041
Data Files path: C:\SierraChart\Data\ | 2020-03-07 10:26:09.041
OS Version Number: 10.0 | 2020-03-07 10:26:09.041
Locale Setting: C | 2020-03-07 10:26:09.041
DLLs: EndedAuction_64.dll, JoboPinch_64.dll, LinearRegressionLocation_64.dll, PeriodLetterDrawing_64.dll, PrevReferences_64.dll, PriceTickDivergence_64.dll, ProfilePeriods_64.dll, ProfileValue_64.dll, ThirtyMinOpenHighlight_64.dll, UserContributedStudies_64.dll, VolumeComparison_64.dll, VolumeTickerComparison_64.dll, WeeklyPivot_64.dll | 2020-03-07 10:26:09.042
Created the DTC Protocol server. | 2020-03-07 10:26:09.047
DTC Protocol Server listening on port 11099. | 2020-03-07 10:26:09.049
Created the DTC Protocol historical data server. | 2020-03-07 10:26:09.049
HD Server Manager | Listening on port 11098 | 2020-03-07 10:26:09.050
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2020-03-07 10:26:09.050
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-03-07 10:26:09.068
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-03-07 10:26:09.239
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-03-07 10:26:09.239
Received 5 login tokens. | 2020-03-07 10:26:09.684
Symbol settings MD5 received. Request ID: 1. | 2020-03-07 10:26:09.927
Symbol settings are up-to-date for cqg. | 2020-03-07 10:26:09.927
CQG WebAPI | Connecting to server api.cqg.com | 2020-03-07 10:26:14.812
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-03-07 10:26:14.812
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2020-03-07 10:26:14.826
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2020-03-07 10:26:14.826
CQG WebSocket | Opening WebSocket. | 2020-03-07 10:26:14.895
CQG WebSocket | Sending WebSocket handshake. | 2020-03-07 10:26:14.895
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2020-03-07 10:26:15.176
CQG WebSocket | Server header | Connection: upgrade | 2020-03-07 10:26:15.176
CQG WebSocket | Server header | Sec-WebSocket-Accept: IM+uFMxxqnkM68b79UnVM1cXq5Y= | 2020-03-07 10:26:15.176
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2020-03-07 10:26:15.176
CQG WebSocket | Server header | Upgrade: websocket | 2020-03-07 10:26:15.176
CQG WebSocket | Server header | | 2020-03-07 10:26:15.176
CQG WebSocket | Web socket state is now open. | 2020-03-07 10:26:15.176
CQG WebAPI | WebSocket connected. | 2020-03-07 10:26:15.176
CQG WebAPI | Sending market data logon message. | 2020-03-07 10:26:15.176
CQG WebAPI | Market data logon unsuccessful. Server message: Username or password is incorrect. | 2020-03-07 10:26:15.339
CQG WebSocket socket (1) | CloseSocket call. | 2020-03-07 10:26:15.363
CQG WebAPI | Disconnected. | 2020-03-07 10:26:15.363
CQG WebSocket | WebSocket closed. | 2020-03-07 10:26:15.363
CQG WebAPI | WebSocket closed. | 2020-03-07 10:26:15.363
CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2020-03-07 10:26:15.363
CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2020-03-07 10:26:15.430
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2020-03-07 10:26:15.430
CQG WebSocket socket (1) | Socket gracefully closed by remote side. | 2020-03-07 10:26:15.501
CQG WebSocket socket (1) | Closed. | 2020-03-07 10:26:15.501
[2020-03-09 01:42:53]
In regards to this error:
Refer to item 4 here:
CQG Trading Platform Service: Common Error Messages
[2020-03-09 03:39:11]
This is my sierra chart name and password.Make sure your broker has configured your CQG account with the necessary Product Enablement's. This is essential to be able to connect. does this need to be done from sierra charts? This worked fine before I tried going through AMP. now my sierra charts name and password doesn't work as well.
[2020-03-09 04:05:08]
It does that make sense you would have ever been able to connect to CQG using your Sierra Chart account name and password. So you need to contact your broker and find out what your CQG username and password is.
[2020-03-09 04:40:54]
when I first signed up for sierra charts I went with rhythmic. then I joined AMP as they offered sierra charts, they gave me a name and password that wouldn't connect. I then tried to reactivate my sierra account and couldn't connect with my sierra name and password. I contacted sierra and you guys said you no longer supported rhythmic. so I then switched to CQG and neither my name and password for sierra or AMP will work. I'm paid up for sierra charts and I'm not sure why I can no longer connect with that name and password.
[2020-03-09 05:30:08]
Could you please just contact your broker to get your CQG username and password to get this issue resolved. We would like to help, but we have no idea what the CQG username or password is or have any knowledge about that account.
This is one of the advantages of the Sierra Chart order routing service. This is not going to be a problem at all with this service:
Sierra Chart / Trading Technologies Futures Order Routing Service
Secondary login issues just do not exist with this service. And you also have much more reliable connectivity as compared to CQG. And the cost of the Denali exchange data feed goes down by 5 USD a-month.
Date Time Of Last Edit: 2020-03-09 05:30:31
[2020-03-09 12:35:39]
How can I switch back to Sierra Chart order routing service. I don't need to go through AMP. just want to get sierra charts back working. Thanks
[2020-03-09 15:10:03]
You just need to have an Introducing Broker or Clearing Firm that is on the list of Step #2 here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
If you do have your account through one of the above referenced firms, then follow through the rest of those Setup Instructions to get setup on the Sierra Chart Order Routing Service.
