Date/Time: Wed, 05 Feb 2025 09:41:38 +0000
Market Depth Scaling.
View Count: 874
[2020-03-07 10:04:29] |
User600744 - Posts: 29 |
I have a market depth heat map on my chart. I have it set so i can see the values of bids and ofers. It shows the numerical value for the size of the bid and offer for each tick increment which is great. However to actualy see the numbers i need to be zoomed in which distorts the look of my chart. Is there a way to combinine the price levels on the market depth to give a value for say every 10 ticks of price range? Thanks in advance for your help. |
[2020-03-07 12:17:56] |
This capability does not yet exist. It is something we will be adding support for as soon as possible.
[2020-03-07 19:05:51] |
Do you know how far off this capability is? weeks? months? Thanks |
[2020-03-10 11:39:29] |
We expect in the next 2 to 3 weeks.
