Date/Time: Wed, 05 Feb 2025 08:55:30 +0000
how to set an alert of a crossover of a chartdraw line on subgruph
View Count: 1486
[2020-03-07 00:23:35]
User199727 - Posts: 10
I set an indicator in subgruph, and also draw a trend line on subgruph, i want to have a buy signal on chart or a buy entry when the indicator crossover the trend line, how to set it on spreadsheet for alert or spreadsheet for trading?
[2020-03-08 23:01:14]
Simple Alert formulas can access Chart Drawings:
Study/Chart Alerts And Scanning: Referencing Chart Drawings
And there is this study which uses a simple alert formula for trade signals:
Trading System Based on Alert Condition
[2020-03-09 04:38:42]
after read the two instruction, I still can not make the alert or entry signal.
the example is on main chart, and it was set to break up an anchor point, not an chart draw trend line. what i want to do is the break of a trend line on the sub graph indicator chart.
I copy the instruction here.
"For example, to set an alert condition when the Last price is higher than the second anchor point for the drawing in the image below, enter the following alert formula: C > UDID[41].A2."
what I plan to do is on sub graph indicator chart, I draw a trend line, when the indicator cross it, give a alert or buy signal.
this is what I do, but not successful.
I have an indicator is on AA column. and I draw a line on sub graph with the ID is 24 two anchors of the line is a1 24.504, a2 -54.50
following this example I try to set the cross trend line on entry cell
K3= =AND(AA4<UDID[24][-1], AA3>=UDID[24][0])
The result is #SYNTAX!
How to fix it thanks.
