Date/Time: Thu, 02 Jul 2026 13:38:29 +0000
REQ: Chart Studies Dialog - make resizeable
View Count: 774
| [2020-03-06 18:26:42] |
| ycomp - Posts: 330 |
maybe you could consider make the Chart Studies dialog resizable? Sometimes there are a lot of studies on a chart and when a user is working on organizing a bunch of them it would be easier to work with a bigger window.
| [2020-03-06 20:24:11] |
This is coming. All of the dialogs are going to be replaced in the Sierra Chart with our own implementation. We are going to finally dispose of the Microsoft ones which are basically trash. So yes, even Sierra Chart has trash in it right now. This is one of our active tasks we are working on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-06 20:24:59
| [2020-03-06 20:28:27] |
great, and if it could remember the size - it would be even better.
Date Time Of Last Edit: 2020-03-06 20:28:38
| [2020-03-10 04:07:19] |
Yes this will be the case.
