Date/Time: Wed, 05 Feb 2025 08:48:14 +0000
I'm getting this error message alert and I'm not able to fix the issue.
View Count: 550
[2020-03-06 15:40:13] |
mbilyanov - Posts: 62 |
Hi, I have created a new chart within the chartbook (a chart with #6). Now, whenever I try to change that new chart's time-frame I get the error seen in the attached image. You have performed an operation which cannot be completed ...
I went through all of my charts within that specific chartbook and none of those is referencing that new chart #6. Any idea about how to fix this? |
Attachment Deleted. sc_error.PNG / V - Attached On 2020-03-06 15:38:48 UTC - Size: 18.15 KB - 191 views |
[2020-03-06 17:32:36] |
Refer to the information here: Chart Settings: Determining References to Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-06 18:02:05] |
Solved. Thank you.
