Date/Time: Wed, 05 Feb 2025 08:54:37 +0000
ZF and ZT ticks problem
View Count: 759
[2020-03-06 06:50:57]
RoScoW - Posts: 2
I have a problem with this 2 symbols ZTM20 and ZFM20.
The price is strange and there are empty lines on the DOM
The settings are on autoset from datafeed.
Can you help me please ?
image7F892800-295C-48EA-90DD-6E20069B3E2D.png / V - Attached On 2020-03-06 06:49:09 UTC - Size: 2.13 MB - 207 views
image014CA097-C51F-4CDE-917F-8C5E4A86EC49.png / V - Attached On 2020-03-06 06:49:18 UTC - Size: 2.25 MB - 225 views
[2020-03-06 06:55:34]
You need to update to the current version of Sierra Chart:
There is a technical notice about this when you start Sierra Chart.
[2020-03-06 12:26:36]
RoScoW - Posts: 2
I tried to solve the problem for hours ...
The solution was so simple :)
Thanks you
