Date/Time: Wed, 05 Feb 2025 09:46:13 +0000
Multiple Custom Drawing
View Count: 514
[2020-03-05 18:58:44] |
Tony - Posts: 549 |
When I have more than one drawings (by using sc.UseTool()) on the chart and they overlay, is there a way that I can control which one is above and which one is beneath? I thought I could do it with bigger or smaller LineNumbers, but that did not work. Thanks! |
[2020-03-10 04:11:02] |
The way this is controlled is based upon the order in which the drawings are added. So you could remove the drawings and then add them in the order that you want them drawn.
