Date/Time: Wed, 05 Feb 2025 09:48:05 +0000
request send Message Log
View Count: 516
[2020-03-05 16:14:32] |
User727587 - Posts: 13 |
i request send a Message Log. The message log states this error: UDPListener (1440). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Each socketadres (protocol/netwerkadres/poort) can only use once (mind you i connect 2 acc at same time sierrachart TT orderrouting |
[2020-03-05 18:51:58] |
Set this setting to 0: Global Settings >> Data/Trade Service Settings >> SC Server Settings >>UDP Port. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
