Date/Time: Wed, 05 Feb 2025 09:54:22 +0000
cqg demo problem
View Count: 923
[2020-03-05 15:33:19] |
User562527 - Posts: 5 |
Hello. I have resgistered to a trial of sierrachart wiht cqg in the AMP web. But the cqg data feed login information donĀ“t work. Could you help me? My user **. Thanks. Date Time Of Last Edit: 2020-03-05 18:12:57
[2020-03-05 18:36:07] |
You do not need to use a CQG trial to trial Sierra Chart. Sierra Chart has its own market data. You just need to use the delayed exchange data feed: Delayed Exchange Data Feed And you can also optionally use the simulated futures trading service: Simulated Futures Trading Service In this way, you do not eventually get locked out by CQG never being able to access the trial again or your simulated account. Also Sierra Chart no longer supports CQG trials. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
