Date/Time: Wed, 05 Feb 2025 08:53:30 +0000
volume by price - hologram bars width
View Count: 922
[2020-03-05 15:05:24]
User156295 - Posts: 104
How to narrow the width of VbP hologram bars?
Which settings are resposible for this?
VbP on the right side example, too wide hologram bars https://prnt.sc/rc2m81
[2020-03-05 16:54:52]
John - SC Support - Posts: 37728
Refer to the information here:
Volume By Price Study: Volume Bars Outline and Fill Colors (SG8)
[2020-03-05 17:09:28]
I was there and Width/Size (SG8) controls only thickness of hologram bar, not width.
https://prnt.sc/rc4tqc
I would need to shorten horizontally width on hologram bars as on the first sent image https://prnt.sc/rc2m81
Pls advise. Thank you.
[2020-03-05 17:19:13]
We assume that you mean the overall length of the bars across the screen. To change this refer to the following Input along with the one after it:
Volume By Price Study: Maximum Volume Bar Width Type
[2020-03-07 14:45:51]
User931593 - Posts: 28
Max Volume Bar Width Percentage should do the trick
attachmentVBP setting.bmp - Attached On 2020-03-07 14:44:49 UTC - Size: 1.37 MB - 343 views
[2020-03-09 11:48:53]
Still one thing is missing.
On 3min bar chart volume profile ends around 2819 on ES.
On weekly bar chart volume profile is far below 2819.
How to get hologram volume bar price study on 3min bar chart with data much below 2800 on es? Like we have on a weekly bar chart hologram volume by price study.
Pls find attached images for 3min and weekly bar chart.
VbP is set to fixed time on both, fixed time is set to 3 years.
3min - https://prnt.sc/rdp5zr
weekly - https://prnt.sc/rdp6lb
