Date/Time: Wed, 05 Feb 2025 09:46:48 +0000
GetLineNumberOfSelectedUserDrawnDrawing does not work as described
View Count: 453
[2020-03-05 14:50:44]
jesslinn - Posts: 108
It appears that this function does not, in fact, at least in 2057 and other recent versions, return the line number of the first selected drawing but instead returns a 0 if no user-drawn drawing is selected and a 1 if one or more user-drawn drawings are selected.
A work-around is to use the result to determine if a drawing tool is selected and then loop through all of them with GetUserDrawChartDrawing and determine which is selected.
Is there a way of selecting multiple user drawn drawings, other than selecting them at an intersection? It would be very useful, for example, if it were possible to hold down the control key and select several drawing tools in order to move them or apply an action to them.
[2020-03-06 05:14:58]
We determined the problem and it is now resolved. A new release will be out today or tomorrow.
No this kind of capability just does not exist at all.
Date Time Of Last Edit: 2020-03-06 05:15:06
