Date/Time: Wed, 05 Feb 2025 09:51:15 +0000
Alert Sounds
View Count: 572
[2020-03-05 12:54:35] |
User221243 - Posts: 1 |
I have an alert manager pop up on my screen from some software I downloaded called Project x. At the moment its says no alert sounds/email on buy and sell signals, i may of changed the settings by mistake. I just wondered how I could get alert sounds for buy and sell signals turned on. Many Thanks. |
[2020-03-06 04:51:37] |
Refer to the information here for setting the sound for an alert. You will need to determine what Alert Number is being used for the Buy and Sell signals: Study/Chart Alerts And Scanning: Selecting a Sound for an Alert Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
