Date/Time: Wed, 05 Feb 2025 09:41:44 +0000
deniali, TT routing + eurex
View Count: 755
[2020-03-05 08:15:56] |
User156295 - Posts: 104 |
I have deniali/tt-routing setup with amp. Choosing this setup with amp like here https://clients.ampfutures.com/live-trading-setup-request causes buying eurex from SC https://prnt.sc/rbv1vt 1- how much is a fee for eurex from SC in situation like above and could it be billed also by amp, I need only one source of billing 2- how about routing in such situation 3- any special settings in platform having setup from amp like above and eurex from SC? 4- I use package 3 if that matters for above Thank you |
[2020-03-05 19:19:16] |
Since you require EUREX our recommendation is to use CQG: CQG Trading Platform Service Once we offer EUREX through the Denali Exchange Data Feed, then it will be easier to use the Sierra Chart order routing service with EUREX. But right now our recommendation is to use CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-05 19:19:21
