Date/Time: Wed, 05 Feb 2025 09:43:41 +0000
Glitch in TWC buttons
View Count: 504
[2020-03-05 01:57:26]
User98657 - Posts: 330
I think there might be a slight glitch when switching from Control Bar > Order Quantity Buttons to Control Bar > TWC Buttons.
I have different control bars configured for each of the markets I trade (5).
Each bar has all six (6) of the Order Quantity buttons and three (3) TWC Buttons. All of TWCs utilize Attached Orders. Each of the TWC buttons is unique to the various markets.
On each of these Control Bars I also have the UAO button.
The idea is to select a TWC button and place an order. As that trade is playing out, I may want to add to it, or redistribute my targets in such a way that requires me to then add a stop or limit order. To this I would deselect the UAO button and then select the appropriate Order Quantity button and add my additional orders. This all works great.
However, when that trade is complete and I then select a TWC I am expecting the Use Attached Orders check box to be checked, but it is not. It is not until I select a second TWC button that the UAO checkbox becomes checked.
For instance:
I'm trading the ES. I select my "ES 6" TWC. I place a trade and the entry and all attached orders are placed. I deselect UAO via the button, select the Order Quantity button "1" and add to my position. That trade comes to an end. I select my "ES 6" TWC and the UAO button is NOT activated. But if i select either of the other two TWC buttons on the Control Bar, the UAO button is then enabled.
The UAO button should be enabled the first time I select a TWC as each of these TWCs were built and saved with the UAO feature.
Thanks for looking into it.
Date Time Of Last Edit: 2020-03-05 01:58:04
[2020-03-06 02:52:39]
What you are experiencing is an internal optimization where if there is no change to the name of the configuration nothing is updated. But we can see why that causes this problem so we will take that out.
