Date/Time: Wed, 05 Feb 2025 09:57:30 +0000
Need help with MESH20
View Count: 622
[2020-03-04 22:16:30] |
User851374 - Posts: 5 |
my Sierra chart trading on MESH20 is doing some crazy stuff. 1. Trading activity log shows that im in possition. and negative in -333.28 2. everytime i placed order long, and took small profit, it showed negative. 3. When i hit flatten (in this ticker), it says "Unable to flatten or Reverse because possition doesn't exist 4. It happens only in MESH20...i downloaded current version and Pre release as well....(multiple times)...logged off and on, closed - re-opened.. 5. CQG platform shows no live order and im in possitive teritory (+ $24.25) But in Trade activity log shows -$333.28 and still open order. 6. I had Tech support from Amp futures log in to my comp multiple times and they couldn't fix it...it looks like it is in Sierra platform In short CQG desktop platform shows all my trade activity to be exactly correct, it is sierra charts that does not seem to be properly showing the correct profit and loss for my account. Date Time Of Last Edit: 2020-03-04 22:24:41
[2020-03-05 03:19:13] |
You are referring to the Trade Statistics for Charts sub window/tab in the Trade Activity Log. For full documentation and understanding of that, refer to: Trade Activity Log: Trade Statistics for Charts (Chart Stats) Tab 6. Do not waste your brokers time with this. They should not have taken the time with this. You really need to switch to this service to avoid this problem to begin with: Sierra Chart / Trading Technologies Futures Order Routing Service For the reason why, refer to: Help With Daily Profit/Loss Value: Consistently Accurate Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-05 14:09:38] |
you are suggesting to use your data feed???? If yes, than i will stop using Sierra chart. Like i said, it happens only on MESH. Order is still there at this moment, unable to flatten...reverse etC.,,...It is not normal... |
[2020-03-05 18:00:10] |
Once again refer to this relevant documentation here about this: Trade Activity Log: Trade Statistics for Charts (Chart Stats) Tab (Trade Statistics for Charts) We have developed the best connectivity and order handling with the Sierra Chart order routing service using TT, much better than CQG. All of the reasons are explained here: Sierra Chart / Trading Technologies Futures Order Routing Service: Introduction You will then have access to very solid connectivity and you have server-side bracket orders. And you have complete fill history with the Position quantity with each fill. If you want the most solid and safe connectivity you would avoid using CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-05 18:01:20
