Date/Time: Wed, 05 Feb 2025 06:50:38 +0000
charts loading super slow
View Count: 486
[2020-03-04 19:13:54] |
User785126 - Posts: 8 |
Does anyone know a way to reset replay chart books. I know it ask to clear there data but when I do a lot of replay on my chart books they take forever to load when I push play or or change a time frame and Im wondering if there is a chache reset or something.
[2020-03-04 23:11:48] |
There is nothing you need to reset. The things to check on are all explained in help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
