Date/Time: Sat, 06 Jun 2026 04:16:09 +0000
BUG: Scale Range Constant Range values lost when linked charts switched in watchlist mode
View Count: 652
| [2020-03-04 18:27:09] |
| ycomp - Posts: 328 |
if you put 2 DOMs side by side - interactive scale range and scale range: constant range checked and set different scale settings : constant range : range e.g. 22 and 87 then link the charts then set a watchlist on the 22 range chart add ES and MES contracts enable watch list mode now switch to another contract from the watchlist the constant range : range values will no longer be the same as they were before this means that once you get your linked doms scaled correctly, watchlist mode is useless as you'd have to edit the scale settings again each time you switched to a new contract unless I'm doing something wrong, I think this is a bug. Date Time Of Last Edit: 2020-03-09 05:26:09
| [2020-03-09 05:26:32] |
This is not a bug. This is normal behavior because there is a resetting of the scale on a change of the symbol.
