Date/Time: Wed, 05 Feb 2025 06:47:51 +0000
Unable to Connect to Transact Data
View Count: 545
[2020-03-04 17:44:32]
jgriddy - Posts: 2
Reading Internal Order ID file. | 2020-03-04 10:50:20.450
Reading Trade Orders file. | 2020-03-04 10:50:20.500
Reading Trade Positions file. | 2020-03-04 10:50:20.500
Reading Account Balance file. | 2020-03-04 10:50:20.500
UDPListener (1424). Port 22903 | Listening on UDP port 22903. | 2020-03-04 10:50:20.510
Software version: 2057 64-bit | 2020-03-04 10:50:20.510
Usage end date: 2020-04-04 | 2020-03-04 10:50:20.510
Enabled for: Sierra Chart Historical Data Service. | 2020-03-04 10:50:20.510
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-03-04 10:50:20.510
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-03-04 10:50:20.510
Current selected Data/Trading service: TransAct WS | 2020-03-04 10:50:20.510
Custom symbol settings values: disabled | 2020-03-04 10:50:20.510
Chart Update Interval: 40 | 2020-03-04 10:50:20.510
Intraday Data Storage Time Unit: 0 | 2020-03-04 10:50:20.510
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-03-04 10:50:20.510
2020-03-04 10:50:20 Local computer time | 2020-03-04 10:50:20.510
2020-03-04 16:50:20 Local computer time in UTC | 2020-03-04 10:50:20.510
2020-03-04 10:50:20 Local computer time in SC Time Zone | 2020-03-04 10:50:20.510
2020-03-04 16:50:20 Server time in UTC | 2020-03-04 10:50:20.510
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-03-04 10:50:20.510
Program path: C:\SierraChart\SierraChartTransActMA\ | 2020-03-04 10:50:20.510
Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2020-03-04 10:50:20.510
OS Version Number: 10.0 | 2020-03-04 10:50:20.510
Locale Setting: C | 2020-03-04 10:50:20.510
DLLs: UserContributedStudies_64.dll | 2020-03-04 10:50:20.511
Created the DTC Protocol server. | 2020-03-04 10:50:20.520
DTC Protocol Server listening on port 11099. | 2020-03-04 10:50:20.521
Created the DTC Protocol historical data server. | 2020-03-04 10:50:20.521
HD Server Manager | Listening on port 11098 | 2020-03-04 10:50:20.522
Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 1. | 2020-03-04 10:50:20.522
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-03-04 10:50:20.572
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-03-04 10:50:20.743
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-03-04 10:50:20.743
Received 5 login tokens. | 2020-03-04 10:50:21.143
Symbol settings MD5 received. Request ID: 1. | 2020-03-04 10:50:21.289
Symbol settings are up-to-date for transact.trading. | 2020-03-04 10:50:21.289
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2020-03-04 10:50:26.159
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2020-03-04 10:50:26.159
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2020-03-04 10:50:26.159
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2020-03-04 10:50:26.160
Auth Websocket | Opening WebSocket. | 2020-03-04 10:50:26.194
Auth Websocket | Sending WebSocket handshake. | 2020-03-04 10:50:26.194
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2020-03-04 10:50:26.312
Auth Websocket | Server header | Upgrade: WebSocket | 2020-03-04 10:50:26.312
Auth Websocket | Server header | Connection: Upgrade | 2020-03-04 10:50:26.312
Auth Websocket | Server header | Sec-WebSocket-Accept: uSGgQfc3hgHmF9jOH5Ps37uXEW4= | 2020-03-04 10:50:26.312
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2020-03-04 10:50:26.312
Auth Websocket | Server header | | 2020-03-04 10:50:26.312
Auth Websocket | Web socket state is now open. | 2020-03-04 10:50:26.312
TransAct WS | Sending account logon message. Live | 2020-03-04 10:50:26.312
TransAct WS | Account logon error: -1(-1) | 2020-03-04 10:50:26.400
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-03-04 10:50:26.400
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-03-04 10:50:26.400
Auth Websocket socket (1) | CloseSocket call. | 2020-03-04 10:50:26.412
Auth Websocket | WebSocket closed. | 2020-03-04 10:50:26.412
TransAct WS | Disconnected. | 2020-03-04 10:50:26.412
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-03-04 10:50:26.412
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2020-03-04 10:50:26.412
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2020-03-04 10:50:26.458
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2020-03-04 10:50:26.458
Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2020-03-04 10:50:26.801
Auth Websocket socket (1) | Closed. | 2020-03-04 10:50:26.802
Date Time Of Last Edit: 2020-03-04 18:39:46
[2020-03-04 18:22:53]
John - SC Support - Posts: 37728
This is the relevant message:
TransAct WS | Account logon error: -1(-1) | 2020-03-04 11:01:17.587
Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError
