Date/Time: Wed, 05 Feb 2025 09:58:50 +0000
Static Charts
View Count: 669
[2020-03-04 16:28:23]
User558377 - Posts: 31
Hello there, I have been running my charts with custom studies with no hicups and now they are static. This has been happening as of late. I just upgraded to the latest version hoping this would fix it. If I restart the charts do update but they are not streaming. I am using TD Ameritrade data feed. I am also running the think or swim charts and they stream just fine so I don't think it their data. Please help. I'm happy to pay for phone support, need to get this fixed. Thank you much.
[2020-03-04 19:41:35]
You could not be using TD Ameritrade because we have discontinued support for TD Ameritrade.
When a chart is open, could you then follow the instructions below:
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2020-03-05 14:26:30]
The charts are still not streaming this morning. FYI
[2020-03-05 17:58:10]
Tell us one of the symbols you are referring to.
[2020-03-05 18:03:40]
RMD
NVDA
AAPL
QQQ
NFLX
none of them work. take your pick.
if I disconnect and reconnect they do update but they do not stream.
Date Time Of Last Edit: 2020-03-05 18:05:24
[2020-03-05 18:47:56]
Those are stocks. For real-time data for stocks you need to use the Sierra Chart Exchange Data Feed:
