Date/Time: Wed, 05 Feb 2025 09:42:24 +0000
Questions about Sierra trade services
View Count: 817
[2020-03-04 15:41:41]
User769498 - Posts: 3
Hello...I hope this is the proper place to ask this question. I was a former Sierra Chart user and am now back to trading futures through TD Ameritrade. I would like to use Sierra Charts and the trade routing and date service from Sierra. I have decided to open an account at AMP Futures. My questions:
1. Is AMP a good choice for me if I want to be positioned for working with Sierra as you develop more service on the trade side? I'd like to avoid jumping from broker-to-broker if possible.
2. If I go with AMP, I assume their free Sierra Chart offering is not exactly the same as buying/leasing from you directly?
3. Finally, if I sign with AMP, I assume I should decline their data service in favor of Sierra's? Anything else I should know as I set this up?
Thanks for your help on all this. And also, thanks for extending my trial yesterday, even though I am a former subscriber.
best,
Mark
[2020-03-05 06:32:00]
1. AMP is a fine choice, but any of the brokers list in Step 2 at the following link will work with our Order Routing service:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
2. That version of Sierra Chart has all the same functionality. The biggest difference is simply that you are locked into the trading providers that are available from AMP.
3. You can sign up for the data either through AMP or directly through Sierra Chart, assuming you are only needing the CME Group for data. In this case it makes no difference, it is just a choice on how you want to get billed (either have everything billed on the AMP statement, or have everything billed through Sierra Chart).
If you need other exchanges other than the CME Group, then you would also need to use the Sierra Chart Exchange Data Feed and pay for that directly through Sierra Chart. You will find the information on the data feeds here:
Real-Time Exchange Data Feeds Available From Sierra Chart
Later this week, we are going to discount the Sierra Chart Exchange Data Feed when used in combination with the Denali Exchange Data Feed.
Date Time Of Last Edit: 2020-03-05 06:32:45
[2020-03-05 12:15:03]
User90125 - Posts: 715
Will the Sierra Chart Exchange Data Feed when used in combination with the Denali Exchange Data Feed give access to the EUREX exchange?
[2020-03-05 19:06:26]
Yes the Sierra Chart Exchange Data Feed does provide EUREX data now.
Date Time Of Last Edit: 2020-03-05 19:07:09
