Date/Time: Thu, 02 May 2024 11:05:31 +0000
Market Internals: UDVR-SP / UDVR-NYSE / USVR-TF
View Count: 966
[2020-03-04 15:28:38] |
User198125 - Posts: 27 |
Hello, Is there any way we can make the market internal ticker 'UDVR-xx' more visually friendly when the ratio is under 1 (denoting more sell than buy) At present, when the buy volume is greater than the sell volume, the display is fine ie. Buy volume = 5000, Sell volume = 2500, display = 2.00 (denoting a ratio of 2:1) However, when the sell volume is greater than the buy volume, it becomes far more difficult to read ie. Buy volume = 2500, sell volume = 5000, display = 0.5 (would be better if this showed as -2 instead of 0.5) Or is there another way to achieve this? Thank you, |
[2020-03-04 18:04:14] |
It's OK, I managed to figure it out using the spreadsheet study :-)
[2021-12-14 05:40:11] |
User575910 - Posts: 13 |
Hey mate, I'm interested in doing the same thing?? Can you please advise how you did this with that study???
[2024-04-06 23:19:09] |
rkg - Posts: 11 |
IS there any solution on how this was accomplished? I am interested in getting UDVR to show both postive and negative values
