Date/Time: Wed, 05 Feb 2025 07:01:19 +0000
Order Fills Font Size Change
View Count: 912
[2020-03-04 11:26:54]
janos bardon - Posts: 42
I'd like to change the font size on the Order Fills, I cannoot see the Text size on the right, how it is displayed here:
Global Trade Settings Windows: Chart Trade Settings
imageChart Trade Settings.png / V - Attached On 2020-03-04 11:23:51 UTC - Size: 79.57 KB - 258 views
[2020-03-04 12:20:50]
This has changed. The font size is now set through this interface:
Graphics Settings: Fonts and Text Appearance
[2020-03-04 21:23:17]
Thanks, I found it, I changed the font size and nothing happened, is there a command that could prevent this?
[2020-03-05 08:02:33]
Make sure you are changing the Font settings through the correct Graphics Settings window. There are two of them. Refer to:
Graphics Settings: Introduction
