Date/Time: Wed, 05 Feb 2025 06:45:51 +0000
Fills
View Count: 492
[2020-03-03 20:32:11] |
User575399 - Posts: 326 |
I’ve been experiencing and heard from numerous sources that ES fills are delayed from the DOM . Is their a reason for this ?
[2020-03-04 11:07:13] |
We see you are using Gain Capital and we can only say that orders submitted from Sierra Chart are immediately sent. However, refer to: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading We recommend using this service : Sierra Chart / Trading Technologies Futures Order Routing Service If you let us know who your introducing broker is we can help you get changed to this order routing service, if possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-04 11:08:14
